GeForce 7900 GT head-to-head
Written by Tim Smalley
April 26, 2006 | 18:13
Tags: #7900 #benchmark #bfg #card #elder #gameplay #geforce #gt #oblivion #review #scrolls #video #xxx
Companies: #nvidia #xfx
Day of Defeat: Source
Publisher: Valve
We used the popular remake of the World War II online multiplayer, Day of Defeat: Source, which uses Valve's implementation of high-dynamic range rendering. We did three five minute portions of real world game play on the dod_anzio map. We connected to three different public servers each with a ping of less than 30ms and 16-20 players in the game when we were recording the frame rates.
Anti-Aliasing and Anisotropic Filtering were controlled from inside the game, and thus the drivers were left set to "Application Controlled". There are three options for the method of HDR used in this title. You can either disable HDR completely, make use of "Bloom" which is just what it says and less resource hungry in comparison to "Full" which, again is just what it says. It utilises a full dynamic range with the iris effect too.
We have written quite a bit about Half-Life 2: Lost Coast, Day of Defeat: Source and how Valve have implemented HDR in to the Source Engine. You can check out the articles listed below for more information on The Lost Coast & Day of Defeat: Source.
CRT gaming:
When using a CRT, we found that the best playable resolution for the three cards was 1600x1200. There were differences in frame rate between the XFX and BFG Tech GeForce 7900 GTs, despite both being playable at 1600x1200 4xTSS 16xAF with maximum in-game details. If you never want your frame rate to drop below 30fps in this game with some very high settings, the XFX GeForce 7900 GT XXX Edition should be your choice.
The BFG Tech 7900 GT OC still delivered a smooth gaming experience, and was perfectly playable, but the frame rate did drop below 30 frames per second on the odd occasion. Meanwhile, the BFG Tech 7800 GT OC was playable with 2xAA 16xAF and maximum in-game details. The minimum frame rate was lower than what was recorded on BFG's 7900 GT OC, but the average frame rate was slightly higher.
Widescreen LCD gaming:
When using a 24" widescreen LCD, we found that the highest playable settings differed a bit more at the screens native resolution. The XFX GeForce 7900 GT XXX Edition was playable at 1920x1200 4x transparency multisampling AA, 16xAF with maximum in-game details enabled. The average frame rate dropped below 50 frames per second, but the all-important minimum frame rate remained healthy, as it only droped to 29 fps during our three five minute run throughs.
The BFG Tech 7900 GT OC was not particularly smooth with 4x transparency multisampling AA enabled, so we settled for 2x transparency supersampling AA at 1920x1200 with maximum in-game details. The 7800 GT OC was unable to play this game smoothly with antialiasing enabled at the native resolution. There were times when the frame rate dropped lower than what we'd say was completely smooth, but the frame rate stayed relatively acceptable - the hitches weren't too common. If you're running a slower GeForce 7800 GT, you'll find that lowering the water detail will help to remove the hitches.
